Results 1 to 10 of 11
Like Tree2Likes
Thread: TT One Goes silent, no voice guidance after a while?
    dfh101 is offline Private
    Cool TT One Goes silent, no voice guidance after a while?
    Hi, i have updated a few TT ones recently, all seemed fine, Switch on no problem new maps, postcodes,speedcams installed. I used mine at the weekend and it seemed ok at first but stopped giving voice directions after a while. I spoke to my brother who's unit i updated as well and he is having the same problem.
    Anyone any idea's what causing this to happen.
    Thanks for looking
    DFH101
    surfjunkey's Avatar
    surfjunkey is offline Sergeant
    Mar 2011
    Norfolk - UK
    57
    Re: TT One Goes silent, no voice guidance after a while?
    if you used the same file on both; it may be a corrupt file - try upgrading to another version to see if the same thing happens
    lemonfish's Avatar
    Melbourne, Australia
    1,073
    140
    Quote Originally Posted by dfh101 View Post
    Thanks for looking
    DFH101
    Which navcore are you using? And which map?
    Losing all sounds after a few minutes is usually caused by lack of RAM trying to run a full featured IQ map. Therefore most likely you are using the wrong navcore for your device which only has 32Mb of RAM. You need to use the right SE navcore that has been optimized for your device.
    Either use your latest official navcore which is probably 7.903 together with a basic map with no IQ routes and no ALG.
    Or you need to use a navcore such as 8.562 SE which is known to work extremely well and smoothly with most ONE models, and only then you can use the full featured IQ map.
    TomTom Tutorials & FAQ
    Thanks for replying, Navcore is 9.026, GPS is 1.20, Boot is 5.5016, 32mb ram with 5.9mb free. TT1 V4
    So I should downgrade the navcore to 8.562 and upgrade the bootloader to 5.5244.
    dfh101
    lemonfish's Avatar
    1,073
    140
    dfh101
    Yes, definitely try the 8.562 SE navcore.
    You don't need to touch the bootloader. Try the navcore first and see how it performs.
    Thanks, Changed navcore to 8.562 se and its working fine now.
    dfh101
    aghumat is offline Private
    43
    Quote Originally Posted by lemonfish View Post
    Hello, I want upgrade my One v1.
    Please, where I can take Nav 8.562 SE ?
    lemonfish's Avatar
    1,073
    140
    Quote Originally Posted by aghumat View Post
    Try here:
    Navcore 8.562.438269
    or here:
    Navcore 8.562 SE
    aghumat and mikie like this.
    43
    Thanks. I try it
    rpaul's Avatar
    rpaul is offline Staff Sergeant
    Jan 2011
    65
    which navcore 9 you recomend for tt go 630
