Results 1 to 10 of 14
Thread: TomTom go 710 charging issue
    rainy911 is offline Banned
    A few months maybe a year ago i updated the software on my 710 via gpsunderground and all was well exept that i have a real problem charging it?
    Did i dream it or did i see a post along time ago on here that the update had a bug in it that gave problems charging? the navcore is 8.370 if that means anything?
    please help
    cheers
    R
    taxi is offline Sergeant
    56
    Re: TomTom go 710 charging issue
    i would check your cradle first, my 710 needs to be angled down a bit to get a charge.
    never heard of navcore problem for charging, iam using navcore 9051 on my go710 no prblems.
    i have to angle mine down also, do you know any fixes for this?
    cheers
    R
    56
    yes new cradle.
    mine is fine just get it in the right place
    Im not sure if it is the cradle because if i plug it into the computer cradle it is still the same, the computer doesnt even find it? if i plug it into the car cradle and then plug the charger into it in the house then if i put it at an angle i can just about get it to charge.
    cheers
    R
    Ok ive found the problem its the small rubber gromit thats missing off the base unit that stops it connecting probly, ive used a bit of blue tack for now. could someone please help me to update the system please as i cant remember how to do it. a noobs walk thru would be really good pleas?
    cheers
    G
    rpaul's Avatar
    rpaul is offline Staff Sergeant
    Jan 2011
    65
    do you mean navcore?
    Yes i think i need navcore! also it hasnt been updated for about a year. i remember last time i did it i had a tomtom type screen that i could use to add maps i think it was! but since then ive got a new putter and lost all my data.
    Many thanks for your help
    R
    56
    need some details of your device, in windows exployer, open your ttgo.bif file on your tomtom in notepad & post contents here
    Here you go my friend,, Thankyou
    [TomTomGo]
    DeviceName=TomTom GO 710
    DeviceVersionHW=GO 710
    DeviceSerialNumber=V54286B04084
    DeviceUniqueID=AKTAL DAGRS
    RamDiskVersion=20090717
    BootLoaderVersion=48600
    LinuxVersion=330021
    ApplicationVersionVersionNumber=8370
    ApplicationVersion=336164
    UserLanguage=English UK
    UserName=V54286B04084
    LastConnectionTime=2008/08/17,13:52:01,UTC
    LastConnectionPhone=,
    GPSFirmwareVersion=GSW3.2.4TT_3.1.00.12-C35B1.02
    BuiltInColorScheme0=Belgica
    BuiltInColorScheme1=Brittanica
    BuiltInColorScheme2=America
    BuiltInColorScheme3=Germanica
    BuiltInColorScheme4=Australia
    BuiltInColorScheme5=Deuteranopia
    BuiltInColorScheme6=Greys
    BuiltInColorScheme7=Antarctica
    BuiltInColorScheme8=Africa
    BuiltInColorScheme9=Astra
    CurrentColorSchemeBuiltIn=0
    CurrentVoiceInfo=Joanna Lumley
    CurrentMap=UK&ROI 835.2419
    CurrentMapVersion=835.2419
    CurrentHomeLocation=
    Traffic=N
    CurrentFuelpricesType=
    CurrentFuelpricesTypeString=
    CurrentFuelpricesLastFullUpdate=
    Features=PlusDownloadDynamic,PlusDownloadGeneral,P lusDownloadMap,PlusDownloadPOI,PlusDownloadScheme, PlusDownloadUpgrade,PlusDownloadVoice,PlusDownload RingTone,PlusMessageNotification,PlusPushChannel,P lusTraffic,PlusWeather,PlusEphemeris,PlusBuddies,P lusMobileSafetyCameras,PlusRoadConditions,PlusFixe dSafetyCameras,PlusFuelPrices,HDTraffic,Hercules,H erculesTraffic,Oxford,TrackMe,PlusOnlineCamera,Plu sTripReporting,OnDevicePayments,HidRemote,HomeBack up,GPRSEngine,VoiceRecording,TTS,TTSCompressed,TTS Loquendo700,MP3,IPOD,MusicPlayer,PhotoViewer,Photo JPGViewer,PhotoBMPViewer,VoiceBrowser,LinkVolumeTo Noise,MapShare,Newyork,Itinerary,Caymann,Durham,Le eway,Handsfree,PhoneFeatures,CarSymbol,TextureRend ering,ExtraSounds,UserSkin,RichPOI,RDSTMC,Prague,B luetooth,SDSlot,Microphone,ExternalModem,SMSSuppor ted,SupportGetAMap,LiveServices
    SupportedPatchTypes=3F
    NrSupportedErrorTypes=132
    UserPatchDatVersion=102
    CompressedPatchVersion=150
    MapServerPatchDatVersion=104
    DeletedPoiDatVersion=200
    ServerLineIndexDatVersion=102
    ServerNameIndexDatVersion=102
    MapShareSupportedProviders=203
    CharacterSet=Latin-1
    VehicleBrand=
    VehicleModel=
    VehicleOptions=
