Thread: [Solved] Please Help Newbie if u can
    Mar 2011
    Hi
    I have used Alberts Activator for My Tomtom Go300 to install new Uk map 865 3259. I connected to Tomtom home and the new maps are there and are fully functional thru Tomtom Home, BUT NOT when I discontect the tomtom from the computer it then says no maps found.
    Any suggestions please, I bet this is so simple to correct but Im afraid its got me baffled.
    Mark
    3,134
    216
    Re: Please Help Newbie if u can
    Use this software to activate original TomTom devices
    MEGAUPLOAD - The leading online storage and file delivery service
    Mar 2011
    Airion
    Many thanks for the quick reply, It worked great thanks again
    Mark
