Thread: Newbie Question about using 2 maps on a TomTom Go 550
    harryklysk is offline Private
    Feb 2011
    Question Newbie Question about using 2 maps on a TomTom Go 550
    Sorry if this has been asked before!
    I was just wondering, can you keep your original untouched Navcore, Map etc on the main memory of the Go 550?
    But, use a hacked Navcore, Map using an micro SDHC card?
    So basically run them side by side?
    I've just bought a Go 550 and am a bit scared to mess around with the original set up.
    If I can't run a hacked map etc from the SD slot, is it safe to re-install a backup, in case something goes wrong?
    Sorry again if this sounds a bit weak and has already been asked before!
    Feb 2011
    Re: Newbie Question about using 2 maps on a TomTom Go 550
    Thanks, Have tried it and it works
