Thread: Help - TTS voices install in ONE-XL
    Binao's Avatar
    Binao is offline Lance Corporal
    Post Help - TTS voices install in ONE-XL
    Hi everyone. My friend have one Device ONE-XL and He already tried install the voices TTS but without success. My question is: Is possible to install this Device?
    Device: ONE-XL
    32 RAM
    App:8.010
    maps: Brazil 8.65-3246
    lemonfish's Avatar
    Melbourne, Australia
    1,073
    140
    Re: Help - TTS voices install in ONE-XL
    Quote Originally Posted by Binao View Post
    Device: ONE-XL
    32 RAM
    App:8.010
    Basically there are 3 things:
    1) You have to make sure you have an SE navcore that works well with ONE models - one that is RAM friendly.
    2) You need to have the right Vocalizer TTS voice that will work well with ONE models. You just copy the folder into the root of the device. I have a modified version of "Samantha" which is very clear and works extremely smoothly - no noticeable lag.
    3) You need to make sure you delete the line "ttsoff" in the setconfig.txt file found in the Config folder or the root of the device.
    TomTom Tutorials & FAQ
    Binao's Avatar
    Sorry. I downloaded a file from the Vocalizer TTS voice Samantha but did not work, maybe it's because of low memory this Device.
    lemonfish's Avatar
    1,073
    140
    It's because you are using the official 8.010 navcore. As I mentioned above:
    Try the 8.562 SE navcore. It is known to work very well with all ONE models, especially your model. Download it HERE
    Binao's Avatar
    Quote Originally Posted by lemonfish View Post
    Yes. I did exactly this and also installed the navcore 9205 SE but unsuccessful. Other users said they can't install this feature because of low memory.
    Thank very much.
    lemonfish's Avatar
    1,073
    140
    Thank very much.
    I have the same device as you, but the smaller 3.5 inch screen instead of the 4.3 inch model. I also have only 32Mb of RAM and have Vocalizer TTS working smoothly - no lag at all, and still have between 5 to 6Mb of free RAM. For my ONE, I use the voice "Samantha" all the time.
    A quick search here found the following thread which will help you step by step. Make sure you download the voices from here only, as they have been modified to work with 32Mb models like yours:
    TTS Vocalizer voices (also Dutch, Italian and German)
