Results 1 to 9 of 9
Thread: Help - Device says Problem with Map - Cannot use this map on this device
    HellfireX is offline Private
    Jan 2011
    Hi all,
    I have a tomtom xl 310 Canada with IQ or w/e.
    I updated my tomtom using tomtom home and it said I was using 9061 so I downloaded one of the navcore for the lazy that matched that number.
    Then I erased my tomtom and then copied the contents of that onto my tomtom so I now have folders like schemes, script, etc.. showing when I view the tomtom.
    I am heading to western Europe and wanted maps for Europe so I checked the compatablity list and it looked like the Europe West 865_3245 map was compatible. So I downloaded it, and then copied the map to my tomtom so I have a folder called Europe_West_865_3245 along with the other folders like schemes, script etc... showing.
    I then attempted to use the meta file thingy - EasyActivator but it gave me an error, it finds the map but when I hit Activate I get:
    -> F:\EUROPE~1\TT8_KE~1.EXE F:\EUROPE~1\ AKTGLAJE36 8
    There is no such key ('Europe_West-297.meta') in keyfile 'Meta.txt'
    'Europe_West-297.meta' - Error
    So I just decided to boot up the device and now it says I can not use the map.
    Please help!
    lemonfish's Avatar
    Melbourne, Australia
    1,073
    140
    Re: Help - Device says Problem with Map - Cannot use this map on this device
    Quote Originally Posted by HellfireX View Post
    Hi all,
    Since TomTom HOME said you were using navcore 9.061, you didn't need to download the same navcore - you already have it! It was not necessary to erase your TomTom drive and download the navcore again from the forum.
    Correct. 865_3245 is the right map - the full featured one that will work with any navcore version 8.2xx or higher.
    Please help!
    There was probably no ttgo.bif file when you tried activating it, hence the error. You can try patching it again. Note that a new ttgo.bif can be created by booting the device on its own.
    If you don't have it already, I strongly recommened FastActivate Premium Edition for patching/activating maps, etc with ease. Download the latest version here:
    FastActivate
    TomTom Tutorials & FAQ
    Jan 2011
    Quote Originally Posted by lemonfish View Post
    FastActivate
    Thanks,
    I used the Fast Activator and it worked!! I can turn on the device and no more map error.... though it does seem to turn itself off automatically.. not sure if it due to the fact I'm not in Europe so the GSP lock wouldn't show anywhere on the map?
    lemonfish's Avatar
    1,073
    140
    Thanks,
    No, it doesn't matter where you live - it shouldn't just turn itself off. Is it just turning itself off or is it restarting? If it just turns off after a while, then it could be one of 2 things:
    1) There is an option in the menu, usually under "Battery saving preferences" that says "Switch off when external power is lost". Make sure this is not ticked.
    2) Low battery. Charge the battery for 2 or 3 hours, but it can take up to 5 hours for a full charge.
    Jan 2011
    No it is definitely restarting.
    lemonfish's Avatar
    1,073
    140
    Delete the file mapsettings.cfg from the map folder. Reboot your device.
    Jan 2011
    No luck, still rebooting on it's own.
    lemonfish's Avatar
    1,073
    140
    Run FastActivate Premium Edition again. Make sure you click on all 4 options in order!
    If that still doesn't fix it, you may need a clean install as a last resort. Do the following:
    1) Backup the entire contents of your TomTom
    2) Erase all the contents of your TomTom.
    3) Run TomTom HOME and run all the updates. Restart HOME as many times as needed until all updates have been completed.
    4) Disconnect the device from the computer.
    5) Start your TomTom device on its own. Wait for it to boot up. Ignore any error messages. (This step creates a new ttgo.bif which will be needed later for patching your map and navcore).
    6) Copy across the folder with the new map into the root of the device. Make sure you just have a folder with all the contents - not a folder within a folder. Rename the map folder to: Europe_West
    7) Copy across the voices folder from your backup, overwriting any files if asked.
    8) Open the contents of the latest version of FastActivate Premium Edition. Copy the file FastActivate.exe into the root of your device.
    9) Run FastActivate.exe and click all 4 options: update meta, maps/voices, patch navcore & Home.
    10) Disconnect your TomTom from the computer. Reboot. It should be working better than ever now
    Jan 2011
    Thanks,
    I ended up having to wipe the tomtom and redoing it all, works now though!! yay! Thanks for your assistance!
