Thread: Tomtom Rider V1 850.2782 meta
    selwynha is offline Private
    Hi all
    Sorry for being a bit dim but I have a Rider V1 Uk which I want to upgrade to Western Europe. I have 850.2782 WE maps but cannot get them to work using Alberts Easy Activator. Do I need a new Meta or do I just need shooting?????
    The Maverick's Avatar
    The Maverick is offline Second Lieutenant
    Bolton București and Bratislava
    316
    104
    Re: Tomtom Rider V1 850.2782 meta
    Try EasytoUseTools to crack the map, patch your unit with ydgpatch and tomtom home and its plain sailing. But use a newer map anyway e.g. 865.3245. You'll get there if you read some relevant threads.
