Results 1 to 1 of 1
Thread: SD Card Speed – Does it matter?
    Silverhawk is offline Staff Sergeant
    79
    26
    I’m setting up a friend’s ONE XL to run from a SD card so he can use maps larger than 1GB. I’ve seen the posts advising not to use SD cards slower than Class 6. However, as an experiment I set up the TT to run from a 4GB SDHC Class 2 card, and it seems to be working fine. My question is, as long as the TT boots up and navigates using the Class 2 card is there any benefit from using a higher-speed card?
  1. 1st November 2011, 06:49
