Results 1 to 10 of 10
Thread: Help - can't get past TomTom screen ???
    bignred is offline Corporal
    Liverpool, U.K.
    20
    Help - can't get past TomTom screen on TT GO 300 ???
    after some help please folks
    a mate has given me his TomTom (think it was a tomtom go 300)
    anyway I'm supposed to be updating it (not looking good now)
    anyway, firstly I put a few TT voices on, these worked
    then My tomtom home took over, this updated a few things
    however now I'm stuck on a tomtom (hands on screen) logo, can't seem to either turn off the tomtom or even shut it down
    anyone suggest the best option
    thanks
    02xdaaus is offline Sergeant Major
    Australia
    162
    Re: Help - can't get past TomTom screen ???
    Hard reset and connect to PC
    Reload from the backup you did before you started playing, if not delete all and let "Home" download the navcore.
    Reinstall maps etc and patch navcore and maps.
    Hopefully you did a full backup.
    Sounds as if "home" updated the navcore and the mapsettings file from the map is not compatible.
    "Clear Flash" may also be required. Either Use BBS tools or it can be downloaded from Tomtom site.
    Cheers and good luck
    Liverpool, U.K.
    20
    Quote Originally Posted by 02xdaaus View Post
    Thanks for the response, now so far its looking good
    after doing a bit of goggling & following some of your advice above
    so far I have managed to do a Hard Reset (several times) tonight I copied all the saved data onto a new 2gb sd card (looking good)
    I managed to get onto the navigation screen, however the battery warning light started to flash, so I'm recharging as we speak
    my next challenge will be to update this TomTom GO300 with the latest software & latest up to date map
    the current software etc is as follows
    App. 5.420 (6543/051108) OS:1008
    30mb RAM (free 6.9mb)
    GPS v1.21, Boot 4.86
    Map: ‘Great_Britian_Plus-Map’ v632
    could someone please advice on the best way forward
    also I have noticed there doesn't to have the speed camera files I'm used to, is this correct ??? how would I update these files ???
    any help/advice would be appreciated, thanks
    Australia
    162
    I would suggest letting "Home" update the navcore. This could take several steps and restarts. To use the "latest" 870 maps you may find you need to go to an SE navcore as I seem to remember the 300 last navcore was 7910 or something. To run 870 maps you need ver 8 or better navcores. Look through the navcore section after home has done it's stuff.
    Cheers
    Liverpool, U.K.
    20
    Cheers
    Thanks for the advice
    however I'm not sure if things are taking a turn for the worse here, as I can't seem to power the TomTom Go300 on now at all
    earlier this evening after doing several restores, I managed to get the original software (what I had kept a copy of) working
    however as the battery was flashing and it was obvious the battery was draining
    anyway I have updated the software via TomTom Home, however I can no longer power up the tomtom, any suggestions
    on a separate note I already have the Navcore (7.910) for my own Navigo based TomTom, could I just use this, obviously should I be able to power the unit up
    Australia
    162
    The Navcore 7.910 on your Navigo is probably Win CE based (PDA) You have a PNA or Actual Tom tom device....No.
    OK. Is the navcore and map on the SD Card or is it on the devices internal storage?
    You need to keep the unit on external power by the sounds of it the battery is dead. I had a 710 that behaved very similar. The battery was so dead it was drawing more power than the USB could supply. I eventually disconnected the battery and only run it from external power now without an issue.
    Leave the unit on charge for several hours, then see how you go.
    Cheers
    Liverpool, U.K.
    20
    thanks for your response,
    to update things, i left the tt unit on a mains overnight charge (about 6-7 hours) tried the unit afterwards nothing, however then i tried. the unit in the. car via cigg lighter socket, the green power light was beaming and the unit worked, all sounds very strange to me
    why can,t it charge via usb lead (same as my sat nav does)
    as for my sat nav/navcore, all the software (navcore & maps etc) run off an sd. card
    could i use this sd card in the tt go 300 after activating it
    THANKS
    Australia
    162
    When you activate the maps you do so according to the unique serial number of the unit. 1 SD Card will not work in another unit. The ttgo.bif file i written every time the unit boots/starts and re writes the serial number etc.
    So to cap off you have a dead mains charger?
    Cheers
    nob14 is offline Corporal
    16
    The map 870-3417 will work on your TomTom Its available on this site.
    Liverpool, U.K.
    20
    Right looks like I'm going rounds here in circles, if its not the power to the unit, its the TomTom Home update which is not working
    Have installed TomTom Home version 1.6 (did the update)
    then installed TomTom Home (latest version 2.8)
    this just produces a blank grey screen
    anyone help me out please
    btw all the software appears on the sd card
    is there any other way to updating the software on this TomTom GO 300 model
    thanks
