Hi mate.. Your in the wrong tread my friend.
You have to look here: FastActivate
Have fun![]()
Hi I have loaded the following :Tom Tom Software with Malaysia maps
The map activation key is invalid ,can someone please help ?
Thanks.
Have fun![]()
Have tried that ,Sorry should have said I'm using Southern Africa Map 885 4088 ,It sees my SD card but when I enter the drive letter it just asks it again.
Thanks.
After looking at all the activation software ,I finally got it patched but now it says not enough memory ,is there a fix for it ?
Thanks.
Hi ,I ran setmem.exe which fixed the memory problem but it still complains about the map. Activation key not for the product.
As far as i know there is still no fix to get tomtom 7 and wince 6.0 working together. the two problems you mention have always been the stumbling block (map activation and out of memory)
This version of tomtom (7.9xx) use anyone of these maps:
885 4004
885 4010
885 4022
885 4058
885 4059
885 4092
885 4093
885 4094
Here's the 885 xxxx compatibility chart:
Hi ,I have searched the forum but all the links to the old maps donot work anymore ,Where can I find it ?
Try this file. Read the readme file and you have to use BNL.885.4058 or Eur.885.4058 Other maps are not working. Wait to hear from you of it works. Mem problem WCE 6.0 (englisch).rar download - 2shared
