Page 1 of 36 12311 ... LastLast
Results 1 to 10 of 357
Like Tree9Likes
Thread: TomTom7 WinCE 4.2 without memory problem
    tabardajun's Avatar
    tabardajun is offline Corporal
    27
    I opened this topic to inform you that TomTomv7.450 already runs on system WinCE 4.2, with no memory problem, and the script is not necessary. The bug is fixed.
    Folder with the complete software, no maps and voices
    Host:MegaUpload
    TomTom Navigato WinCE4.2
    Host:RapidShare
    To unlock map use tt7_keygen.
    At the first time says memory problem, but starting again, is running at 100%.
    pd32, sopiebaba, efendi and 1 others like this.
  2. The Following 23 Users Say Thank You to tabardajun For This Useful Post:
    Guidorenato's Avatar
    Guidorenato is offline Command Sergeant Major
    202
    Re: TomTom7 WinCE 4.2 without memory problem
    Quote Originally Posted by tabardajun View Post
    I opened this topic to inform you that TomTom7 already runs on system WinCE 4.2, with no memory problem, and the script is not necessary. The bug is fixed.
    Hello ....
    I tried it on my Medion 250T WinCE 4.2 but starting it from TomTom Navigator.exe I have memory error, always.
    I also tried to compress the file with UPX, but the problem remains.
    Maybe others will work.
    I will continue to use my program with Autorun, this works without putting Mapsettings.
    tabardajun's Avatar
    27
    Workin on Mio269+ with WinCE4.2 a 100%.
    202
    Ok, but if it works on Mio 269 Plus is not guaranteed to work at 100% for all devices, one must be cautious ...!!!!
    Each device has a different problem.
    This is the version 7.450 not 7.910.....
    Suppper ......
    It work´s on the Ndrive Touch SE without problems .....
    Many thanks ...
    greetings from Portugal
    localshop is offline Private
    out of memory error on navman icn 520
    edit
    kept restarting and it sorted ifself out after maybe 20 restarts
    still a bit slow [30m behind me most of the time] - but working
    hello world
    Existing TomTom7 WinCE 5.0 without memory problem
    202
    Quote Originally Posted by toto13015 View Post
    hello world
    TomTom 7.910..... for WinCE 5.0 does not have memory problems ..... works ..!!!!
  10. The Following User Says Thank You to Guidorenato For This Useful Post:
  11. #9
    Hi Folks, Thanks for the post. It works on my WinCe 4.2 device with a 8.40 map. However, the clock is jumping around like crazy and therefore also the GPS position is not fixed. My little arrow jumps around and doesn't stay on the road most of the time. I have chosen "Other NEMEA GPS receiver" with 2400 Baud which seems the only setting that works. Any of you had this problem and know a solution or a workaround? Thanks, you help is muchly appreciated! Cecile M
  12. #10
    202
    Quote Originally Posted by freeewilly View Post
    For the problem you
    Try this, it works on my device.
    1. Get the file and unzip.
    2. Get files Autorun.exe Autorun.ini them and copy the TomTom folder.
    3. Autorun.ini file is set to work with the SD called Storage Card
    4. If your SD card has a different name changed Storage Card and put the name of your SD
    5. Also check the path and file names contained in the command line
    6. Start the program -->Autorun.exe
    Autorun
    Pass:Guidorenato
  13. The Following User Says Thank You to Guidorenato For This Useful Post:
