Results 1 to 1 of 1
  • 1 Post By Orni
Thread: Using v975 maps without metas available
    Orni is offline Staff Sergeant
    Jan 2011
    Special v975 maps
    Activation of maps with equivalent metas. If you have a map that has no meta, you may be able to activate it if there is an equivalent meta.
    So, in simple terms (Northern_US_and_Canada_975_7750 example):
    Download/decompress/copy the map that you want to activate (but for which you don't have the meta).
    Delete the relavent .meta file
    Copy into the map folder the .meta file from the other map (same country - compatible as number) for the same country
    Activate the map with the usual system.
    For example:
    Copy map Northern_US_and_Canada_975_7750
    Delete map 975_7750 meta file (Northern_US_and_Canada-100878.meta)
    Copy the meta of 975_7749 (Northern_US_and_Canada-100877.meta) that has meta code into map 975_7750 folder
    Unlock the map.
    The equivalent numbers are:
    975.7685 = 975.7686 = 975.7687 = 975.7751 = Truck = 975.7766
    975.7689 = 975.7691 = 975.7748 = 975.7749 = 975.7750
    rotson likes this.
  2. The Following 2 Users Say Thank You to Orni For This Useful Post:
