Thread: navcore one 9.061
    Jan 2012
    navcore one 9.061
    i have just installed navcore ONE 9.061 and installed 895.4438.does with navcore come with a asr folder with in the navcore..
    atb
    Jan 2012
    Re: navcore one 9.061
    right i installed navecore 9.061 should there be a folder within the navecore files called ASR..????????????
    Chris86 is offline Lance Corporal
    Nov 2012
    I have also 9.061 but i do not have a map ASR. So probably you can delete it...
    boynewaters is offline Corporal
    Nov 2012
    Glasgow U.K
    15
    same here put navcore 9.061 on my ttone v3 and cant find a uk map that will work with it , 895.4472
    lemonfish's Avatar
    Melbourne, Australia
    996
    131
    Quote Originally Posted by boynewaters View Post
    The latest 900_4602 one will:
    United_Kingdom_and_Republic_of_Ireland_900_4602 LINKS ONLY
    TomTom Tutorials & FAQ
    TomTom GO 730, Navcore 9.051c, 64Mb RAM, Australia 900.4602, Bootloader: 5.5250
    TomTom ONE v1, Navcore 9.170SE, 32Mb RAM, Australia 900.4602, Bootloader: 5.5244
