Results 1 to 10 of 12
Thread: How do I get Voice Control (Voice Recognition) on my GO730?
    Jadog is offline Corporal
    26
    [solved] How do I get Voice Control (Voice Recognition) on my GO730?
    I am currently using a Navcore (by TTuser) version 9.026. I would like to have the Voice recognition that the GO740 offers. Is this possible?
    214
    Re: How do I get Voice Control (Voice Recognition) on my GO730?
    Quote Originally Posted by Jadog View Post
    Is this possible?
    Yes , and super EZ to fix.
    A text file called support_asr.dat with ONLY the number 1 in it.
    NOTE: I attached the file. Unzip it and put the file in your ASR folder on the 730
    Attachment 846.
  3. The Following User Says Thank You to ChillyCat For This Useful Post:
    26
    Quote Originally Posted by ChillyCat View Post
    Attachment 846.
    Ok, so I did that, but when I turned on my 730, I didn't notice anything different. Is there a place I need to enable it?
    214
    26
    Ok, I just realized I should probably clarify that the voice recognition works by saying the city or street, as you show in the example above. I'm looking for the menu control voice recognition, like turning the volume up or down, or by saying "Navigate to Home".
    *edit
    I just figured out that I needed to have a computer voice loaded and active for VR to work. Once done, a microphone shows on the main screen...
    Thanks to all who helped!
    Paris
    Hello i have the same problem on a GO 720 , before a crash i have the voice control.
    I install an SE 9.101 navcore and a maps 8.35 , i have the TTS but not the voice control
    i create a folder called ASR to put the file in it but no resultat , can you help me please
    thanks
    26
    Apparently you need more than just a single file in that ASR folder. Get the complete ASR folder here: Next, make sure you have a computer voice in your voices directory (you may have to remove some other voices if you don't have enough room). I used Samantha from this link: This is what worked for me.
    Paris
    thanks , with the ASR full folder they works
  10. #9
    Sifu1 is offline Private
    Chillycat.
    I have similar issues, I made a new Folder ASR and put in that missing file, I even added all the files they said to add that worked for them in the ASR folder but my SPOKEN ADDRESS and SPOKEN ADDRESS (dialog) is greyed out? but my Voice Recognition works fine. I can click on the MIC and get it to CALL HOME or Navigate home no problem. Can you assist?
    I'm using 9.101 with go630
    Thanks.
  11. #10
    Joecap's Avatar
    Joecap is offline Sergeant
    41
    does this file also work on the Go 920? because when i updated my map the file now is missing it says file not found
