Thread: Go 700 and SE 9.051 - Strange Bluetooth problem
    First I want to thank all you guys for your efforts and help. You guys rule.
    Now the problem:
    Since I updated with 9.051 everything works as it should except the following:
    X40 emulation works fine except there is no setting for auto day/night switching.
    So, I set it to x50 emulation to get auto day/night switching. Now any time I try to make a call with the BT handsfree I get no sound at all - not from my phone call and then not from navigation instructions - until I do a reset. Navigation sound will work fine until I place or recieve a call while linked through BT and then all sound disappears.
    Does anyone know of a config that will preserve both BT calling and day/night switching on the Go 700?
    Thanks for your help.
    HZ
    PS: since my most recent update I no longer get the tomtom drum sound on a hard reset - is that caused by a different bootloader version?
    terryuk22 is offline Sergeant
    Birmingham
    33
    Re: Go 700 and SE 9.051 - Strange Bluetooth problem
    did you find a navcore that works as i have the same problem
    No luck so far. Any suggestions?
