RunMeForCode (create a meta/blowfish code from genuine map)
Thanks to ??? for this which is based on the good old Easytools
Help.txt incl:-
How to create meta (blowfish) codes
you have to be the original owner of the map.
1. Plug your tomtom device with USB to the computer
2. copy RunMeforCode.exe to your TomTom device map/voice directory or run it directly from desktop
3. Run RunMeforCode.exe
4. Done... meta.txt created in map/voice directory
5. Copy/paste contents of this meta.txt to share with others here:- tomtom-maps
This tool based to TTuser Easytools
remember... meta data not contain any personal information from you or your device. It is safe to share
History:
RunMeforCode 1.0.0.1 - First release
RunMeforCode 1.0.0.2 - Fix to double results
RunMeforCode 1.0.0.3 - Just icon changed
This tool is also integrated to FastActivate
hello
can you upload in mediafire o Rapidshare
thanks
thanks
P33dro
Tried is on Western_Europe-562 (Western_Europe_890_4222) but for some reason it doesn't create any meta.txt.
Any idea what that might be?
iafilius, it sounds like you're trying to extract the meta out of a map you have downloaded from here. That won't work! It has to be a genuine map that YOU have purchased.
tenorman, read the first post. "You have to be the original owner of the map" to use this tool. Whether or not the meta code is available for other maps such as 890_4222 is irrelevant.
TomTom Tutorials & FAQ
TomTom GO 730, Navcore 9.051c, 64Mb RAM, Australia 900.4602, Bootloader: 5.5250
TomTom ONE v1, Navcore 9.170SE, 32Mb RAM, Australia 900.4602, Bootloader: 5.5244
same here... After official update from W_and_C_Europe_2GB-452 880.3810 to W_and_C_Europe_2GB-562 890.4222 and following steps in help for RunMeForCode, no meta.txt generated... Might be reason that map isnt in internal flash but on sd card? App detects internal tt drive, but no sd card, I tried to enter both drive letters but no success :-(
