45Likes
10th June 2012, 03:05
#21
Re: TomTom Official Speed Cams by Maverick
Thank you for the work that you realize disinterestedly
A greeting . Thank,s.
16th June 2012, 14:34
#22
Speedcam files copied to map folder, activated but still don't work??? any ideas i'm using a tomtom one
21st June 2012, 01:28
#23
have you cracked ttsystem as well, or just the speedcam files? Have you run in demo mode along route with known speed cams? They definitely work on TT One when done correctly
21st June 2012, 01:39
#24
Thank you very mutch !
Im going to travel from norway to serbia via
Norway - Denmark -Germany - Czech Republic - Hungary -Slovakia- Croatia - Serbia
And your updates on speedcams is gold worty ! Thanks and have a cool summer
23rd June 2012, 10:06
#25
The Following User Says Thank You to The Maverick For This Useful Post:
Hello i cannot seem to get the speed cams to show up on my tomtom xl i boot ver 5.5277 map ver united kingdom and ireland 890.422 nav 9.061 downloaded the files opened folder copied all to map folder ran fastactivate and still have nothing can someone help where i have gone wrong many thanks
First have a look in the mapfolder if the .dct files are created for the speedcams. If that is alright then go into the tomtom menu and look for services. Because TomTom speedcams are no poi's but services which you have to enable.
You can actually only see them when drive next to them so run a demo route.
The Following User Says Thank You to duur1duur For This Useful Post:
Autovelox Premium+Normal 03-07-2012
The Following 3 Users Say Thank You to maghero For This Useful Post:
Re: Autovelox Premium+Normal 03-07-2012
Updated post #1. Sorry, I could not upload on Tuesday. Seemed like a connection prob so after 30 mins gave up trying. Next Friday, driving to Romania for a couple of weeks, so I won't be able to upload, though will be updated by colleague on a different site in my absence. So if you see them, feel free to get
The Following 2 Users Say Thank You to The Maverick For This Useful Post:
'TomTom Official Speedcams 06.07.12'
The Following 4 Users Say Thank You to maghero For This Useful Post:
