Here is the updated file for Europe as of 13:00 BST
Default fuel type is Diesel.
Running the script prior to copying the files to your unit allows you to have the correct fuel type set if in Europe or USA/Canada
Cheapest nearby - search within 5km/3.1miles - "Pricing Information for this location is unavailable" displayed if no price is available for the specific fuel type within 5km
Cheapest in area - search within 50km/31miles - "Pricing Information for this location is unavailable" displayed if no price is available for the specific fuel type within 50km
Find by distance - search within 10km/6.2miles - "--" displayed if price is not available for the specific fuel type regardless of whether the station sells or not this fuel type
Find by price - search within 10km/6.2miles - "--" displayed if price is not available for the specific fuel type regardless of whether the station sells or not this fuel type
Cheapest on route only works if you have a route set - and only if available.
Use appropriate files in your map directories.
These are cracked in the same way as the maps and speedcams. Use easytousetools and place the files in directory C:\Easyusetools_for Keygen_Mapcheck_Metacheck_ttsystempatcher\insert_m eta_from_Map_here
If you find you have no places in the POI, it is because you have not got the dct file, or you have and your PNA is unsuitable for this Live service
Dependent upon your navcore and your settings (emulation) you will only see fuel prices on GO units and/or those supporting Live functionality. Does not appear for WM software and basic units without SE navcores emulating high spec units.
TomTom update the prices every 4 hours. During summertime this start at 1am, during winter and us back to GMT, this starts at 0:00 am. Hope that helps.
Decided to add the little script FuelType.cmd to the rar file, so you can export to mapdirectory and using Windows Explorer, put to your fuel type from within the map directory very simply after you have created the dct file.
If you have problems with it, you should not be downloading stuff for free, read through what it does and how, and figure what you are doing wrong yourself.
If you do not subscribe, why do you expect Home to update your files? Works with GO and One units. Incidentally, the files are updated 4 hourly at 0:00, 04:00, 08:00, 12:00, 16:00, 20:00 UTC, so in summer this is at 1,5,9,13,17,21 BST
