Thread: Need help - zip codes for usa
    rabinthe hoose is offline Corporal
    24
    Hi, Wondering if anyone can help.
    I have a Tom tom XXL, when i look into the route of the tomtom there is no "ZIP" file at the bottom.
    Im really struggling here, can anyone help????
    I am going to the USA shortly and have downloaded the new navcore and maps for the usa and installed it into the tomtom.
    Everything works fine.
    When i looked back into the route of the tomtom menu I have just noticed, however, that there is no zip/postcodes file for the USA.
    Does anyone know if there is a such a thing, and if so, does anyone know where i can find it????
    Tearing my hair out now trying to figure out what is wrong with it.
    PLease please help
    jarkita's Avatar
    jarkita is offline Captain
    Plymouth / Warszawa
    615
    52
    Re: Need help - zip codes for usa
    US postcodes are included within a map. Did you check if you can navigate to a postcode?
    rgds jarkita
    24
    Didn't check that but have done so now. Its all there. Thanks for your help.
