Page 1 of 7 123 ... LastLast
Results 1 to 10 of 63
Like Tree20Likes
Thread: [PGPSW] Pocketgpsworld Speed Camera Database.
    Dolnad's Avatar
    Dolnad is offline Lance Corporal
    here is Speed Cam the UK zoned 7.4.2010 and others 31.3.2010, as a starter post.
    Attached Files Attached Files
    Re: PGPSW Speed Camera
    Hi.
    I can't get this to work on my tomtom oneV4 V7.903. Is there a patch or a crack I can use to make this work?
    Thanks.
    jarkita's Avatar
    jarkita is offline Captain
    Plymouth / Warszawa
    615
    52
    Quote Originally Posted by jimby_tron View Post
    Hi. I can't get this to work on my tomtom oneV4 V7.903. Is there a patch or a crack I can use to make this work?
    Thanks.
    Copy all (.ov2 and .bmp) files over to a map folder, setup a warn near poi within tt menu.
  4. The Following User Says Thank You to jarkita For This Useful Post:
    jarkita's Avatar
    Plymouth / Warszawa
    615
    52
    Rest of world consolidated 7.04.2010 courtesy of original uploader
  6. The Following User Says Thank You to jarkita For This Useful Post:
  7. #5
    cleggy's Avatar
    cleggy is offline Corporal
    South Yorkshire, UK
    24
    are these going to be updated very regular pls as these are over a month out of date
  8. #6
    jarkita's Avatar
    Plymouth / Warszawa
    615
    52
    Quote Originally Posted by cleggy View Post
    As long as some kind and clever (to clean the files before sharing) donator will do ... Weekly updates are available for annual fee of GBP 19.99 from here
    http://www.pocketgpsworld.com
    And you can share afterwards
  9. #7
    alf
    alf is offline
    heres the voice alerts to to go with this + instructions
    http://www.pocketgpsworld.com/speed-camera-alerts-tomtom.php
  10. #8
    xmassacrex's Avatar
    xmassacrex is offline Sergeant
    34
    Thanks for the download Dolnad. I have took the liberty of consolidating the UK zoned files as people like me prefer them
    Just extract and copy over. If theres any problems let me know.
    Used POIedit to consolidate uk zone speedcams.. Any problems let me know. Will update when i can
    liumingsteven likes this.
  11. #9
    spudgun is offline Lance Corporal
    re: [PGPSW] Pocketgpsworld Speed Camera Database.
    Would it be possible to have the zoned version of the June cameras please xmassacrex? Or, as you are crediting the original uploader in post 1 are these a consolidated version of the 7th April 2010 release?
  12. #10
    xmassacrex's Avatar
    34
    Hey Spudgun. These are the June UK consolidated speed cameras (UK zoned converted using poiedit) Just extract and copy to your maps folder.. I have thoroughly tested these and they are all working perfectly. Let me know if there are any issues.. Will update when new ones are released
