Results 1 to 8 of 8
Thread: TT speedcams problem
    All I can say is WOW, Thanks You.
    First time trying to install new maps onto my TT and managed to do it first time with this great little tool.
    I installed GB & Ireland 850.2820.
    Now if I could find the speed camera updates I'd be one happy chappy.
    jarkita's Avatar
    jarkita is offline Captain
    Plymouth / Warszawa
    615
    52
    Re: Albert's EasyActivator5
    Quote Originally Posted by Mancbloke View Post
    Sticky in POI section.
    rgds jarkita
    Quote Originally Posted by jarkita View Post
    Found them
    Thank You
    I downloaded, installed and used EasyActivator.
    It said it had created the .DCT files for both the maps and Safety Cams, the maps work great but the Cams don't show up and there isn't a category for them in the POI section.
    Any help would be great thanks
    jarkita's Avatar
    Plymouth / Warszawa
    615
    52
    These are not POI, use tomtom services menu to set warnings up, they will show up either on route or route demo.
    rgds jarkita
    Got them working now.
    Thanks for your help
    I´m going mad.
    I think i have read all tips about installing speedcams but it will simply not work for me.
    I have a TT One XL navcore 8.010 and are trying to get the latest cams to work on scandinavia maps. I used Easy Activator wich worked well for me when I installed the map itself and a custom voice.
    Could someone please help me?
    116
    maybe you could give us more details..
    Speedcams don't work together with "simple" regular radar cams. So if you have both for for same country you won't make them work.
    Just delete all cam files you have for now, then choose the ones you want for the map that you have, put them into your map folder (each country have 2 files for same type of camera so you copy both), then just update meta file and patch using FastActivate or any other patcher
