Results 1 to 9 of 9
Thread: Surfjunkey's UK/EU Speed Camera Updates (Continuous)
    surfjunkey's Avatar
    surfjunkey is offline Sergeant
    Mar 2011
    Norfolk - UK
    57
    TomTom Official ALL Speed Camera Updates (Continuous)- Latest Updates 26/04/11
    This thread will be continually updated here when the new updates become available via tomtom. I will update this 1st post all the time as the updates become available.
    All the speedcamera's have the country code so you can install all - or just the one's you require .
    Overview of all safety cameras in Europe. The most up-to-date and complete speed camera database for TomToms.
    ALL Speedcameras
    Update 26/04/11 (26th April 2011).
    Place desired files in your map folder on your device & use an activation tool (found on forum) if not already done so.
    There Are No Problems - Only Solutions
    If you appreciate my work - use the thanks button - a little thanks go's a long way.....!
    surfjunkey's Avatar
    Mar 2011
    Norfolk - UK
    57
    Re: TomTom Official ALL Speed Camera Updates (Continuous)- Latest Updates 18/04/11
    updated 18/04/11
  3. The Following User Says Thank You to surfjunkey For This Useful Post:
    Apr 2011
    hi
    can i know what's the difference between premium and tomtom speedcams?
    many thanks
    149
    23
    Quote Originally Posted by aficionado View Post
    hi
    many thanks
    Premium are supposed to be more up to date and contain more types mobile,traffic light etc
    surfjunkey's Avatar
    Mar 2011
    Norfolk - UK
    57
    speedcams latest update 26/04/11
    Apr 2011
    thanks for explaining
    May 2011
    Hi surfjunkey,
    My Tomtom Go 300 (navcore 9.051.503855.2, Boot 5.5259, Map UK and Ireland v865.3256) cannot load the speed cameras in the POI.
    I put all files in its map folder & used an activation tool successfully. However these cameras don't show up in the POI category. Do you have any idea?
    Thanks.
    May 2011
    Re: Surfjunkey's UK/EU Speed Camera Updates (Continuous)
    Just noticed that there is no .bmp files in your database, is it a possible root cause of the problem I mentioned above? Thanks
  10. #9
    Bitchkilla is offline Sergeant
    Apr 2011
    51
    Quote Originally Posted by coolhighgo View Post
    Hi surfjunkey,
    Thanks.
    Thats because they are not POI's.
    Access/setup is through, at least on my Go 300 with a NC of 8.204, Tomtom Services then Tomtom safety cameras.
    Regards
