Thread: speed cam showin but no warnin sound
    bigfella is offline Sergeant
    32
    hi i recently modded a tt520 go to a trucker s on a sd card , recently took the sd card out n put bac in n now the warnin sounds dont cum on when i do a route demo ......have tried goin into menu... tomtom services...
    tomtom safety cam warnin prefences and resettin them and every thing looks ok but still no warnin sound ...the warnin symbol cums up but no sound wonder if any one can help ???many thanks in advance
    32
    Re: speed cam showin but no warnin sound
    ok i think i ve sorted it .... for some reason the speed cam warnin sounds on the orginal navicore on the tt go 520 thats on the devices internal memory reverted to silence ....so i set them all to polite 3 ....bing bing .....then had to reset all the warnin signs on the tomtom truckers sd card ..usin gps sound voices recording eg warnin gatso ahead...and it seemed to fixed it .....t f ....
