Results 1 to 10 of 11
Like Tree10Likes
Thread: Current Original speedcams (no premium)
    daniele's Avatar
    daniele is offline Corporal
    26
    Autovelox Normali 12/1/2012
    Attached Files Attached Files
    andysue is offline Private
    Sep 2011
    Re: Current Original speedcams (no premium)
    Hi
    I am trying to convert these files to asc files but they appear to be encrypted by TT. This means that I cant use them.
    Any idea how to get them unencrypted or can you provide normal ov2 files that are unencrypted?
    any help would be appreciated
    Andy
    The Maverick's Avatar
    The Maverick is offline Second Lieutenant
    Bolton București and Bratislava
    316
    104
    TomTom speedcam files are encrypted. You use the meta.txt file with a suitable tool so they can be used. Suggest you read some tutorial guides
    Sep 2011
    Am I right in thinking that this all has to be done on a TT?
    I do not have a TT & have to put the files inside a POI Warner programme that sits in my old Medion 96800 from Aldi.
    I have to use POI Edit to transpose the files into asc.
    All this has to be done on a computer & also I have to dual boot into XP to use microsoft Sync as Mobile Sync in windows 7 is not compatible for the Medion as I cant back it up or restore my files when the battery goes flat.
    I refuse to give in to these companies that try to rule the world there is usually a work around.
    I shall do a search for meta.txt with a tool & have a read but I suspect you cant use it in a computer.
    Andy
    May 2011
    Hi Maverick,
    still in trouble to silent the tutor warning sound.
    I have a TomTom Navigator 7.915 (9196) and I'm not able to find the path you suggested me.
    Any experience with that TT version?
    Thanks a lot in advance.
    Best.
    316
    104
    I am not sure why. It works with all the units I have. Will have a further check this weekend, but it should work with any TomTom. It works from Classic 300 to GO Live 950 here that i've checked. Even works on my PDA too. Sure you are following instructions correctly?
    rotop is offline Sergeant
    52
    24
    You have to create the folder \Sounds in the root.
    That folder is not there by default.
    Howerever I wonder if .wav files will be read by Navigator.
    Convert the silent .wav file to silent.ogg file and it will work.
    You can also try to put a file in there containing 0 bytes called silent.ogg
    Make that file with Notepad containing nothing.
    Choose that sound in your safety cam settings.
    Quote Originally Posted by cirodi View Post
    Hi Maverick,
    Best.
    316
    104
    I maybe wrong, and to be honest haven't checked, but the speedcams point to \sounds directory for sounds, and they are all wav files. The ogg files are kept in the same place as the points of interest and have the same name as the poi file. I think they are for totally different things. One being for Services and the other being for points of interest.
    52
    24
    Finally I checked it. Both .wav and .ogg sound files can be choosen from the folder \sounds when you
    change the settings of your speedcams. And they work fine.
    So I know now both type of soundfiles work in Navigator. And the 0 bytes file is OK too.
    And for POI's it is exactly the same. You can choose soundfiles from both types and the name
    is not relevant. Can be any soundfile name.
    Note:
    Not to be mixed with .bmp filenames for POI's.
    These files should have exactly the same name as the POI in order to show
    a POI on the map.
    Quote Originally Posted by The Maverick View Post
    May 2011
    I want to thank you both to get in this discussion.
    Could you help me in identifying what is in the TT settings the speedcam icon associated to the Tutor?
    Thanks.
    Best
