9700 (.ori _SE and DSA) Not valid for trucks
Hi.
On the road, I saw that this nav, 9700 (.ori .SE and .DSA) is flawed and cannot be used to work with a truck.
Look at the screenshots: they refer to the N14 in Trofa, Portugal, passing under a railway bridge .....
http://i49.tinypic.com/2guaxwi.jpg.......)
the limitation is: towards the north "limitation of height 3.5 m", and towards the south "limited to all trucks" and "limitation of height 3.5 m" .....
(....http://i48.tinypic.com/34gajwz.jpg
(On your map the limitation will be wider, I have it corrected to the real stretch)
http://i46.tinypic.com/2ng69er.jpg http://i46.tinypic.com/oqkoki.jpg http://i47.tinypic.com/34ypxnc.jpg http://i47.tinypic.com/6pb02q.jpg http://i46.tinypic.com/34t8x9w.jpg
If we prepare a route with this configuration between the extremes, towards the north, it is done by skipping the limitation in planning (precisely the most necessary), (but if we are on the point it shows us the warning.
http://i50.tinypic.com/k532mc.jpg http://i50.tinypic.com/2mxna0.jpg
the correct route is traced by the 8398
http://i45.tinypic.com/ekhslw.jpg... http://i45.tinypic.com/35d6lpv.jpg
A greeting.
Re: 9700 (.ori _SE and DSA) Not valid for trucks
Thanks for the work mate. Not only have the text translated from Spanish to English, but you've taken the trouble to make catches in English.
Good work, thanks Pesado (Heavy)
I doubt if TomTom informs correction.
What is certain is that if TomTom Home detects 8.398, attempt to update navcore 8.398 to 9.700
Quote:
Originally Posted by
bihurkatu
The application is not correct. but map is correct
Driving a truck that's dangerous.
Pesado
No I doubt it.
I insisted my brother until he retired.
bihurkatu
No I doubt it.
How dangerous is driving with the 9700 nav
http://i45.tinypic.com/343l02f.jpg
Pesado
I do not doubt what you say.
Map 901 has no updates.
The photo does not say if the nav. is 8.398 or 9.700.
I do not think the 8.398 is much better, the map is the same.
I think I'm too old ...
I answer and does not publish the message forum ...
bihurkatu
Post #7 is up now
This picture is just an example of danger by height, we should not use the wrong 9700.
The example of the defect can be seen.
http://i45.tinypic.com/ekhslw.jpg <> http://i47.tinypic.com/6pb02q.jpg
You can try the route in this stretch, and see the result.
The biggest danger is not to know where it can repeat the error.
