Originally Posted by
Megalos
First, thanks for your problem and solution.
This is a known problem. There are two solutions: 1. Go back to v8 NavCore or 2. Use the v850 maps. These Vocalizer voices are actually meant for the 32MB RAM devices (like most of the ONE's and XL's). For 64MB devices (like the GO's), I would recommend the Loquendo voices. These Loqendo voices are better than the Vocalizer voices, but also require better CPU and more RAM. Therefore, for devices with 32MB RAM and a 266 MHz CPU, I made these Vocalizer voices. The Juliette voice you are using is a Loqendo voice, and is the right choice for your TomTom. But for the "Low Spec" devices, this is not an option.
