Results 1 to 7 of 7
Thread: sound doesn't work on tt 630,please help
    rpaul's Avatar
    rpaul is offline Staff Sergeant
    Jan 2011
    65
    after installing Navcore 9058 and Europe 865.3245 Map, sound and voices dont work
    214
    Re: sound doesn't work on tt 630,please help
    Have you attempted to D/L a computer voice directly, using TT Home ? (see if that wurks)
    rpaul's Avatar
    Jan 2011
    65
    hi,ive tried to download a computer voice on tt home,but it does not show any to download
    norbert51's Avatar
    norbert51 is offline Private
    Put the computervoices from your backup in your navcore 9058
    TomTom Go 730>NavCore SE 9.430>Europe 925.5412
    rpaul's Avatar
    Jan 2011
    65
    do i have to patch voices?
    Drivee is offline Private
    Apr 2011
    yes, after wrong patch itc do not work..
    Apr 2011
    I have the same problem ! I upgraded my GO 930 to Navcore 9.101.516023 and put the v865.3244 and can't have the voice guidance !
    could you tell me where to find the soud files on my backup and how to patch them once installed on the new navcore ?
    thank you very much for your help !
