Thread: Newb help with premium voices
    Mike Carew is offline Lance Corporal
    Apr 2011
    Hey guys, hmm
    I have a tomtom xl 330s (aka a tomtom one v9)
    I have a SE Navcore 9.205.547817 for 32mb devs.
    Everything works fine, my updated maps, and the navcore.
    Except my premium voices do not show up. I've tried unlocking them with 3 different programs. Is there something I'm missing?
    Are there any options I can change or need to change in the SE navcore, maybe the emulation?
    Right now it is set at x50 (I heard it was more compatible for some reason) but if there is a different emulation or any other suggestions I would appreciate it.
  2. The Following User Says Thank You to Mike Carew For This Useful Post:
    Apr 2011
    Re: Newb help with premium voices
    thnx for the quick response.
    Ive followed that guide and also tried some other tools.
    got my voices in that folder
    all 3 files, and then the tool creates the .dct
    And after its finished, everything's looking good, I turn on my tomtom, and only non-premium voices show up.
    I've tried having premium voices being the only ones on there.
    I thought maybe I got a curropt voice, so I dled a 140 voice pack from here, and still all the premium voices did not show up. I will try adjusting my emulation in my SE navcore, only thing I can think of
    *edit* I tried changing my emulation to original, and my tomtom started freezing, im lucky I got back into it via usb, so I will not be changing my emu settings, any other ideas what I can do to fix the voices?
    Quote Originally Posted by biggerdave View Post
    They should be in a folder called "voices" and each should comprise of a data**.chk, data**vif & data**bmp then use one of the tools to patch (create a data**.dct for each).
    Plan b) have a look through this: http://gpsunderground.com/forum/tomt...um-voices.html
    Apr 2011
    29
    Hi there Mike
    when asked by the tomtom do you wish to use only english voices say NO!!!.
    you then scroll through and you should find the new voices listed and you can then select them.
    Apr 2011
    It never asks me, it simply says there are no compatible voices found (if I only load premium voices on it)
    It does show the free Chinese and Japanese voices, so I know its not a language problem
    Quote Originally Posted by cedewriter View Post
    Hi there Mike
    214
    Have someone get you a pre-compiled voices folder with your language.
    Then, can't see how it could fail
    The Maverick's Avatar
    The Maverick is offline Second Lieutenant
    Bolton București and Bratislava
    316
    104
    Just updated a One XL v9 for a friend with new maps, speedcams fuel prices etc and all premium voices. No issues here, but using normal cracked navcore rather than a special. Cracked with YDGPatch tool and map and others with EasytoUseTool. Seemples!!!! Free bottle of vodka given. Fuel prices did not show, but that was all.
