Thread: TNS400 Yaris 2008 - Help Please
    Speed111 is offline Sergeant
    56
    Hello everyone,
    From what I gethered by reading some of the threads, the TomTom system in my yaris cant be modefied like the conventional TT Go 700. I dont have any disks for my car. I found out that I need a Gen5 disk Eurpoe north. (I need Poland in my maps )
    Can someone please point me in the right direction to get the best possible version?
    Thanks in advance to anyone that can help me out.
    Thanks again.
    Re: TNS400 Yaris 2008 - Help Please
    If you have a TomTom lookalike where would you envisage putting the DVD in?
    Are these thought not a bit silly? But then again you're in Poland
    The unit runs from an SD card and nothing else
    By the way it is called TNS400 and not TomTom
    56
    I just bought this car recently. I've been playing around with the regular TT nav's. Maybe I should have looked around more before posting...
    But if this unit runs straight from SD, is there a conventional way to updating the maps like XL series? I have read some other threads with the TNS system running from SD card, looks like its very tricky to even copy the SD.
    You cannot copy the SD card and there is no other way for updating than to purchase a new card
    kab
    kab is offline
    Hi all,
    I try to find a map (if possible FRANCE) for my tomtom TNS400 (Toyota Yaris). Is there someone who can give me indications to find and download a map? It's just to be able to listen to CDs and MP3 USB ^^
    Thanks a lot !
    Hello.
    What you ask is possible. I've done recently, carrying maps Iberia 860.3126.
    First, take a backup of your SD card. There are some cards that you can not use the cut and paste from windows, do not know if they are defective or because they are protected. Better use a backup utility like Cobian Backup.
    Second, spend the backup to a new SD card, newly formatted, and delete the directory that brought the TomTom map.
    Third, load the map you want to use. Here you'll have to try different versions, as the TSN400 not accept them all. I believe those who have IQ Routes and Lane Guide do not work, so try one of the most basic.
    Third, the patch and generate a file ttsystem meta.dct as usual. There should run you.
    I used a utility called "Easyusetool" and did great
    Sorry for writing. I use the google translator.
    Good Luck!
