Thread: P5700 software update problem HELP
    bobel06 is offline Private
    Hi all
    Ive got big problem with this satnav. Ive founded newest software for it on this forum
    burn it on cd , put in sat it ask for update i preesd ok and.. 10 min of waiting screen black i can hear cd spinning from time to time 15min and nothing. So i took the key form car to try restart it and now its not turning on cd still spinning screen black and i cant teake cd off from reader its not responding at all
    Re: P5700 software update problem HELP
    If you burned a CD that is not really 100% good this is exactly the behaviour you would expect.
    The mistake you made is to pull the key from the ignition first.. If you had ejected the CD, you would have had a chance to save the unit
    I have seen this happen many a time before and in 9 out of 10 cases the PC has been damaged beyond repair except from a specialized service centre
    You can safely say goodbye to your PC5700
    hell is offline Lieutenant General
    1,410
    i think - as the unit havent started the flashing- that the unit CAN be saved by a proper disc, it is just stucked halfway between normal operation and flashing( of course with flash mode flag set on). the improper disc is probably written in mode1, the unit simply cant reboot itself from the disc.
    so, first get a PROPER disc, release the stuck disc and retry from the proper disc.
    and goddamn who releases update discs in iso and nrg format which is simply not suitable for these discs, there formats solely rely on the goodwill of the burner and the burning application...
