Thread: Problem with PC 5200 copy tool on dvd
    man20cese's Avatar
    man20cese is offline Staff Sergeant
    92
    Hello, I downloaded the maps 2009\2010 for vdo dayton pc5200 with 2 sd card ports from the links from gazo in another post in page 2 of this section. I have a problem to use the tool included in the dvd to creata the sd card with the maps. It give me this error:
    I tried in a pc with winxp and another with windows 7 with java installed, last 21 version.
    How can i do to copy the maps into sd? Can I copy only the folder named "map" without use this fucked tool!? Sorry for my english..I'm Italian!
    Re: Problem with PC 5200 copy tool on dvd
    Yhe problem is well known and is caused by a Java incompatibility issue.
    The only solution seems to run in Safe Mode
    You cannot just copy maps to the SD card, you will then miss the sub-directory structure
    If you do have an earlier SD card you can of course make the map structure yourself
    VDODayton/Maps/Europe_Navteq_2009_10 Copy all the files from the Data/Europe/Map directory
    VDODayton/ and copy the complete TPD directory from Data/maps/TPD
    man20cese's Avatar
    92
    Re: Problem with PC 5200 copy tool on dvd 2009\2010
    Very thanks Gazo, I started winxp in safe mode with f8 and the tool magically started to make his work! I'm think about people who spent a lot of € in this original DVD and then become furious with this problem......:X
    Mar 2011
    I had the same problem even in safe mode! The answer was to unzip the iso file & replace the java with the current java files from my computer then re-iso it.
    However my 5200 pro will not accept the maps language or software sd cards. It tells me on startup that " no sd-map for language installation in the computer please karekte sd-map insert " German-english translation.
    Are the pro maps the same as standards pc 5200 I wonder or is this a faulty unit?
    You have either a DVD image that you can burn or mount and start the installation program or you have an image with a folder VDODayton which you can directly copy to an empty SD card
    The best solution is to start the installation program with start_console.bat
