Thread: VDO Dayton 5400pro questions
    bob12345 is offline Lance Corporal
    All,
    I have a 5400 and have just updated the maps with the exit code (Thanks you whoever posted that!!) But have some questions....
    I have noticed speed camera alerts on my C-IQ page, can i get this working?? or is it already set to now I have upgraded??
    Also I have a TMC unit I have not installed yet.. If I install this will it work??
    I have used the unit to get from a to b but that is it, any other tricks I may have missed that this unit can do??
    Re: VDO Dayton 5400pro questions
    Settings-Info points-Traffic alerts
    You tick the box and also the alert box and off you go
    The TMC will work once the box is connected.
    After the cable is plugged in you will have to disconnect the supply to the navi unit completely otherwise the box will not be initiated by the navigation computer
    5400pro Camera's
    I have the 5400 and asked a little while ago about speed camera's that was great, but after driving around for a bit have some more questions...
    It seems that the cameras only get notified if I am following a route. Is their a way of getting the alert like the speed warning, so no matter what state the computer is in the alert comes up.
    Also is their any way of getting a sound when coming near???
    I'm using the latest TA disc but looking to move to NT if that makes any difference....
    Re: 5400pro Camera's
    You only receive a warning when guidance is active. There will be a pop-up displayed.
    There is no other way of being notified without guidance
    In the Infopoints menu you can tick the box with traffic violations. If you press OK again on the remote control a small loudspeaker will appear behind the tick box indicating that audible alerts are activated
    This is also explained in the owners manual
    Switching from TA to NT does not make any difference
    Another thig: once you start a new topic please stay with it as long as you have the same problems and do no start a new topic every time
    Thank you and sorry, I'm a little new to the whole forum thing.... I'll give that a go..
