Thread: VDO Dayton PC 4000 Help
    kpeti077 is offline Sergeant
    41
    Hi guys,
    My friend's got a VDO Dayton PC4000 equipment.
    Do You know what's the correct disk for this unit?
    CD or DVD ??? CI-Q or Non CI-Q ???
    Thanks!
    Re: VDO Dayton PC 4000 Help
  3. The Following User Says Thank You to gazo For This Useful Post:
    41
    Hi gazo!
    Thank You for your quick answer! I'll try it...
