Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: problem with vdo dayton pc5600
    vlada33 is offline Corporal
    Dec 2010
    Hi...
    i have a few problems with my navigation...until yesterday it worked properly (at least I think so), but yesterday it stopped working properly, now when I insert the CD in the navigation for a moment to load maps and then throw a message that I need to use the original CD and looked for a service.
    i buy it few days ago and everything was fine
    I have the original cd and just react to them with the same instruction.
    If someone has an idea what to do now let help...
    vdo dayton pc5600
    sw 0120
    Re: problem with vdo dayton pc5600
    That is tyical something that would happen if you have not yet unlocked your system with a Supercode and are still using the old C-IQ cd's with a limited use only
    http://gpsunderground.com/forum/show...1764-Supercode
    Dec 2010
    gazo thanks...
    but already I've seen the story on this and I typed this code though is the same as the one I had on the cover of the CD from 2007-2008 (they came together with the navigation) and then appeared the problem, now does not accept any CD, for a moment to load and immediately turns off the menu where the maps, only a part of the personal settings, C - IQ and stand-by. now I can not I type in because that part is blurred.
    what next can I check
    and sorry if my English is not good, but I try ...
    thanks ...
    I am sorry that you do not understand anything that is written
    It is impossible that you already have a code on the CD from 2007-2008
    Please read the instructions and try again after you have done exactly what is written there
    If you do not have a CD with SUPERCODE printed on the surface it is impossible to enter the 16 digit code
    The fact that everything is blurred means that the trial period of the original CD has expired
    The moment you enter a Supercode CD you will be able to enter the code from the TeleAtlas website
    Dec 2010
    here there is one small problem and I think I'll check and realized a couple of hours if it is what I mean ...
    with navigation I received two packages from cd has 2006/07 and 2007/08 and the latter is one code with 16 broja.probable needed after a switch to another car to type in the code which I did not do it.
    now I turned off the power supply and navigation back to, is it now necessary to type the code?
    It is extremely difficult to advice you if you continue this way and do not read what has been published sofar
    Please for once do exactly what I have written
    Obtain the Navi ID of your unit from the C-IQ menu ( 8 digits)
    Go to the TeleAtlas site and obtain a Supercode
    Burn any Supercode cd and insert the cd
    Enter the supercode in the C-IQ Enter code menu
    If you still do not understand what is supposed to be done, I am afraid we cannot offer you any more assistance
    Dec 2010
    hi Gazo...
    I already done what you told me to do,and the massage says that the code cann't be entered twice...the navi is working now after a short turn off from power supply,but i guees it will stop again after few days...here are picture a hope that i do this right....
    same this code i am getting in the teleatlas site
    and message
    Everything is ok now and you cannot enter the code twice. So the supercode has unlocked your unit
    The picture of the Europe map 2007/2008 looks like the package of a DVD
    But what are you doing with a Supercode DVD that was sold in the Netherlands by Navco to a Mr Michiel Wijn with the supercode printed on a label?
    This Supercode is for just one specific C-IQ navigation only!
    The Supercode DVD inside this package cannot be used in your PC5600 since it is for CD use only. Or is this package a complete set of 6 cd's for Europe?
    How did you obtain this 5600 ?
    Dec 2010
    no,this is not a dvd this is 6 cd...
    Navigation has been installed in a car that was imported to my country from the Netherlands and the man who imported the car was removed from the car navigation and sold it to me. navigation is sold together with two packaging CDs from 2006/07 and 2007/08 and this code on the envelope.
    I live in Serbia and Serbia since the maps are not helpful to the man he sold it does not travel anywhere but it suits me because the monitor I use for DVD and Navigation
    And again the same happened, the navigation still does not accept the CD, obviously has something to do with what is still connected properly and I have not got any GPS antenna. as soon as the short turn off the power supply is working properly again ...
    Without a proper GPS antenna it can never work which is something I do hope you realize!
    Something seems to be defective I'm afraid and it is hard to tell from a distance what the problem is
    The original 2006/2007 CD which have C-IQ printed on them can never been used again and may be dumped.
    Anyway, this system will not help you very much with navigation since there is no coverage for Serbia
