Thread: to help to burn map for vdo dayton mm5000/01
    barto30 is offline Staff Sergeant
    70
    106
    Question to help to burn map for vdo dayton mm5000/01
    with that program can burn the cd for vdo dayton mm5000/01 (imgburn or magiciso)
    Re: to help to burn map for vdo dayton mm5000/01
    Nero, MagicIso etc
    Burn in Mode 2
    This is also discussed in the download item!
    70
    106
    meaning as in mode 2 ????????????????? I do not understand (I modify the program in mode 2)
    If you do not understand I suggest you use google
