Thread: MS4400 C-IQ Supercode Help
    Apr 2011
    I hope someone can help. I've just purchased a "new" old stock MS4400 unit complete with the original C-IQ 2006/7 Europe 10 CD map set.
    I downloaded the latest map Supercode 2010/11 set from this forum and retrieved my supercode from the Teleatlas website. The Supercode was accepted by my MS4400 unit.
    However, if I insert the Supercode 2010/11 map CD and navigate to the "my C-IQ" and then "activated products" its says the expiry date is 04/04/2013 under each of the regions (two years from now). It displays the same expiry date regardless of whether I have the 2010/11 or the 2006/07 cd in the unit.
    I thought the supercode meant that there would be no expiry date? What have I doing wrong?
    Thanks in advance.
    PS - I'm using the latest Operating Software version.
    Re: MS4400 C-IQ Supercode Help
    The information in the C-IQ menu is not of any signiicance anymore after the Supercode was entered successfully
    And the C-IQ information only refers to the use of C-IQ media, not the Supercode discs
    Apr 2011
    Hi Gazo,
    Thanks for you help on this matter
  1. 29th July 2011, 15:13
