Page 10 of 10 FirstFirst ... 8910
Results 91 to 93 of 93
Thread: Firmware 4120
  1. #91
    jomafi's Avatar
    jomafi is offline Second Lieutenant
    Jul 2011
    Rottweil, Germany
    321
    18
    Re: Firmware 4120
    Change communication protocol from DDP to BAP and your Display wil work. But i think there arealso other things to code. The 4120 delete coding from RNS510 because its a factory version
    B.R. Jomafi
  2. #92
    Niko Šušnja is offline Private
    Jan 2013
    Re: Firmware 4120
    Quote Originally Posted by jomafi View Post
    Thanks , about coding , what is different in 4120 , in byte 10 type what? , I have passat b7 and 4020 is o.k but , 4120 make problems.
  3. #93
    jomafi's Avatar
    Jul 2011
    Rottweil, Germany
    321
    18
    Re: Firmware 4120
    in byte 10 only set 00. Then its ok, but the byte 10 shpould also have 00 in 4020 too!
    Go in long coding and check if your environment of car, e.g. Rear camera and so on is correct coded, otherwise code it with long coding.
    B.R. Jomafi
