Page 2 of 10 FirstFirst 1234 ... LastLast
Results 11 to 20 of 93
Thread: Firmware 4120
  1. #11
    ramzes99 is offline Private
    Jul 2011
    Re: Firmware 4120
  2. The Following User Says Thank You to ramzes99 For This Useful Post:
  3. #12
    May 2012
    Re: Firmware 4120
  4. The Following User Says Thank You to krzychmen.ka For This Useful Post:
  5. #13
    May 2012
    Re: Firmware 4120
  6. #14
    Sep 2011
    Re: Firmware 4120
    I wil try it
  7. #15
    Jul 2011
    Re: Firmware 4120
    This soft is for C8/C9 too.
  8. #16
    Jul 2011
    As this is a factory CD, will it reset any coding for Bluetooth, SDS, etc?
  9. #17
    Aug 2012
    Re: Firmware 4120
    I am getting an SWL Error 010306 (no description). Burner, speed and disc is the same as with 3810noru and 4020 for A units that I just recently installed. It is a HW04 Columbus B (at least now it is B...) unit. Does anyone know if I can install this version anyway or if I have to wait for a modified version like 3810/4020?
  10. #18
    BossHog's Avatar
    BossHog is offline Second Lieutenant
    Oct 2011
    Holland Germany Belgium
    254
    104
    Re: Firmware 4120
    You wanna do whát with that screwdriver
    Read this thread for a quick usenet-reader-setup: http://gpsunderground.com/forum/feed...et-manual.html
    Look in my profile for more usenet-info: http://gpsunderground.com/forum/member.php?u=301179
    PM possible in English-Deutsch-Nederlands: http://gpsunderground.com/forum/priv...newpm&u=301179
  11. #19
    Jul 2011
  12. #20
    noogi is offline Private
    Jul 2011
    Re: Firmware 4120
    Quote Originally Posted by sslneve View Post
    You should wait for modified software.
    This software is to C6-C12 units.
