Page 3 of 10 FirstFirst 12345 ... LastLast
Results 21 to 30 of 93
Thread: Firmware 4120
  1. #21
    BossHog's Avatar
    BossHog is offline Second Lieutenant
    Oct 2011
    Holland Germany Belgium
    254
    104
    Re: Firmware 4120
    Software Loading CD for CP2 based units
    (c) CONTINENTAL Wetzlar
    CdTreeBuilder version 3.06 is used.
    #CD:P 0 0 5 . 5 4 1 . 9 0 1
    #DATE:2012-03-16
    #Project: VWRNS
    #Author: SaRo
    #Steckbrief: C_EU_16.120_t2 C10/C12/C6
    #CommentStart:
    This is a SWL CD for VW delivery.
    #CommentEnd:
    #Integrationphase: Delivery cw22/12 C10/C12/C6-samples
    #VwSwPartNumber:1T0035680D/3T0035680B/7F0035680A/7E0035680A/1T0035680H/1T0035680J/3T0035680E/3T0035680F
    #VwSwIndex:4120/4120/4120/4120
    #AppsBuild:C_EU_16.120_t2 C10/C12/C6
    #CRC16:826c
    (confirmed working on a 1T0035680D btw)
    You wanna do whát with that screwdriver
    Read this thread for a quick usenet-reader-setup: http://gpsunderground.com/forum/feed...et-manual.html
    Look in my profile for more usenet-info: http://gpsunderground.com/forum/member.php?u=301179
    PM possible in English-Deutsch-Nederlands: http://gpsunderground.com/forum/priv...newpm&u=301179
  2. The Following User Says Thank You to BossHog For This Useful Post:
  3. #22
    Garb is offline Private
    Re: Firmware 4120
    If you have back camera and dynaudio installed, this will be removed after update and then you need to have vag-com to reinstall
  4. #23
    Dec 2011
    Netherlands
    Re: Firmware 4120
    I got 4120 working on a RNS 510 B version H11 (build feb 2009)
    -After the update to 4120 your rns will be in factory settings, including the long coding, so you will need vag com to recode your RNS
    -Hdd music and personal POI was formated, maps was still on it
    -All presets on the radio memory were erased
    everything seems to work smooth
    me happy
  5. #24
    Nov 2011
    FRG
    Re: Firmware 4120
    The installation of this FW made some trouble on my RNS:
    SWL error, if I tried to install from a CD-R. In a German forum some further people report the same problem.
    Solution: Burn the FW on a DVD.
    With this FW my RNS starts up much faster than with FW 4020 or 3980. My RNS is a C8 sample.
    BTW: I was surprised, that a factory CD doesn't format the entire HDD.
    Note: VCDS is required to encode the RNS after the update.
  6. #25
    Sep 2011
    Re: Firmware 4120
    I have to burn it on a DVD too. (a CD-r make an error)
    I have to recode the RNS, for the format the POI and radio memory are format but not the Music and map.
  7. #26
    stakyrTSI is offline Private
    Oct 2011
    Re: Firmware 4120
    What type of encoding must be done after this sw update?
  8. #27
    Sep 2011
    Re: Firmware 4120
    The coding is delete. The RNS use the original coding 0000..00000
    You have to re-code with VCDS
  9. #28
    Oct 2011
    Re: Firmware 4120
    Is it possible to save the long code and after the update to paste it again?
  10. #29
    Sep 2011
    Re: Firmware 4120
    Quote Originally Posted by stakyrTSI View Post
    Yes you save the code with VCDS and past it after the update.
  11. #30
    Mullay is offline Private
    Re: Firmware 4120
    Hi
    i have a problem with installing FW 4120 on a C6 LED Unit,FW before is 4020.
    Update goes up and finished HDD,than Radio up to 56%,then breaking up,cd comes out,"Error Description"
    i testet fw on a cd and a dvd
    On C10 Units i can install the 4120 with this CD or DVD perfectly without problems.
    anyone has a solution ????
