Use map 7918 without manipulated POIBase and all will be good!
I update an F unit, from oct 2011 to 5218 and now no POI apear, i try 3 different version of maps, 7894, 7896, 7920, all 3 works on 4020.
How safe it's to downgrade to 4020 ? last time when i try do do this i bricked an H unit , from 5218 to 4120 , black screen apear, after checking enable downgrade
Also media player from Blue tooth meniu not apear in the IC menu, with H versiion works.
B.R. Jomafi
@Jomafi
7918 is for West, i need East Map..
Ok, sorry, then use 7919
B.R. Jomafi
indeed, with 7919 , POI appear on screen with 5218 firmware, but no Speedcams and Traffic Lights included.
Thanks to mr. jomafi.
i just extract and update from SD card POI with Speedcams and TrafficLights from 7921 and put it in my F unit, software 5218, CD_7919, POI apear, but no Speedcams and TrafficLights..
In PoInspector apear both.
Very strange..
Thank you!
Is there any posibilities to downgrade unit from 5218 back to 3890 or 1100 ?
I got C4 unit with 5218 software crashed.
When i try to downgrade 1100 or any version it stop on HOST update and give error.
Kind Regards
gsmflasch...
Hello. I from Poland. I heve naigation rns 510 hdd 30GB. My firmware navi in A. Please tips I gonna do that?
3P0 035 680 A = vag number
componet = RNS-mid H05 0996
for me, also CD_7921 not work with POI from 7919..
the only combination when POI works is CD_7919, but in 7921 are more streets in my area.
can someone put the POI corrected/updated that works with 7921 in 5218 firmware?
Thank you!
or i thinl the problem is MAP not the POI..
@mark21: I think you're not right about the streets in your area, because the basic of the 7921 is the 7918. Only the pois are included in 7921. All streets and the coverage ist the same as 7919
B.R. Jomafi
