Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 50
Like Tree12Likes
Thread: VW RNS510 Western Europe V.9 (7918)
  1. #21
    Nov 2012
    Re: VW RNS510 Western Europe V.9 (7918)
    I downloaded the file, burned it with IMGBurn onto a Verbatim DVD+R DL.
    When I insert the DVD into the RNS510 it just loads the map, it does not ask me if I want to install into the hard drive.
    I dont know the exact version of my firmware (Dont have access to the secret menu), but I know it is pretty low/old - could this be the cause of the problem?
    Thanks!
    Cheers
    Christian
  2. #22
    Nov 2012
    Hi
    Downloaded and burned on DVD
    when inserted it says system being activated, then it report not compatable, insert a VW DVD
    any advise
  3. #23
    doerrt is offline Sergeant
    45
    Volkswagen RNS 510 Westeurope V9
    • Format: img
    • Sprache: Multi
    • Hoster: Share-Online.biz
    • Hoster: uploaded.net
    • Größe: 4,1 GB in 110 MB Parts
    Download
    Uploaded.net
    WV9
    Share-Online.biz
    Passwort
    pr1nz
  4. #24
    Jamerson is offline Sergeant
    Jan 2012
    43
    thank you for the map,
    a questions about the FW, does it work on all FW?
    does this map contain Personal POI and speed cam?
    much appreciated it
  5. #25
    jomafi's Avatar
    jomafi is offline Second Lieutenant
    Jul 2011
    Rottweil, Germany
    346
    19
    Yes work on all Firmwares.
    Have no personal pois, only the vw standard pois, but you can use personal poi on SD Card to import into the system
  6. #26
    Keks777's Avatar
    Keks777 is offline Sergeant Major
    May 2011
    177
    VW RNS510 Western Europe V.9 (7918):
    Download one file:
    filezpro.com
    filepost.com
    uploaded.net
  7. #27
    ibrahin77 is offline Lance Corporal
    Dec 2012
    Thanks for aportation
  8. #28
    delange001 is offline Private
    Mar 2011
    very thanks for this
  9. #29
    Jan 2013
    Hello. I need some help. I would have started a new topic, but this board doesn't allow me to until I have created 10 reply posts (seems a little backwards to me)
    Anyway, I downloaded and burnt this, and it loaded into my car fine (VW Toureg with RNS-510) but now I have no roads on my screen. Its like the area I am in (Oxfordshire) is not included.
    I don't know what version of RNS-510 I have, I can take a photo but not sure that helps. How can I find out what firmware I am running? I don't really want to take it out to find out model numbers, etc. Is this the only way?
    Should I download some older maps and try them?
    Any advice gratefully received.
    Many thanks, Chris
    And sorry for dragging up an old thread, its just I thought if I \have\ to reply to a thread, it should be the one that I downloaded.
  10. #30
    jomafi's Avatar
    Jul 2011
    Rottweil, Germany
    346
    19
    Normally this map works with all firmwares available on the RNS510. Propably its not correct installed on HDD. To see which firmware you have installaed and which model it is without take out the device (Its really very easy on Touareg to take it out) you must activate the hidden menue. This can be done by the vw dealer with his VAS-PC Diagnostic Interface ore by a user with VCDS.
    B.R. Jomafi
