Re: Problem with MFD2 and 'MFD2 DVD Version 2013 V10'
Have you the possibility to use a LG Burner? for example GSA-H12N or compatible. The LG Burner are the best for burning Map-DVD. The DVD-+R DL from Verbatim is ok. And if the unlock has worked correct, the map must activate automatically.
Use as Burnsoftware Nero Burning ROM and the lowest possible speed of burner. In my case its 2.4 speed. And all DVD-R i burnde with this GSA-H12N worked very well
For testing use the Lite-On with Nero. Hope it works.
B.R. Jomafi
