Page 2 of 33 FirstFirst 123412 ... LastLast
Results 11 to 20 of 325
Like Tree14Likes
Thread: MFD2/RNS2-DVD Unlock- and Firmwarethread
  1. #11
    Jan 2013
    Re: MFD2/RNS2-DVD Unlock- and Firmwarethread European Devices
    Hi Jomafi!
    If I have Passat with firmware 22, which version is for my car? Firmware 28 or 30?
    What is the difference?
    Thanx.
  2. #12
    pipi87 is offline Private
    Nov 2011
    Hi!
    I updated to firmware v.30 and it has changed my language to german.. how do I get it back to English? thx
  3. #13
    jomafi's Avatar
    jomafi is offline Captain
    Jul 2011
    Rottweil, Germany
    532
    30
    The language is always dependent of the DVD. It can only changed with DVD inserted. So insert Map-DVD, the go to settings (Einstellungen-Systemeinstellungen) and change the language (Sprache) to english. Ho i can help you...
    Greetzz!
    B.R. Jomafi
    Repairing of RNS 510 with Setconfig, Coding with VCDS, ODIS and VAS-PC
  4. The Following 2 Users Say Thank You to jomafi For This Useful Post:
  5. #14
    Nov 2011
    Oh ok, thank you
  6. #15
    Nov 2011
    @jomafi : hi, thank you for your uploads. I have done everything as described but I can't make it work... I will write step by step what I did and please correct me what have I done wrong. I have VW multivan T5 2005 year.
    1) First I updated firmware to v.030 (RN S2 CB 1.6) - that went ok
    2) Then I burned image of unlock DVD (all firmwares) at 2.4x using Alcohol 120 - I am not sure that went OK, because when I put the cd in, it reads and those two bars are quickly compleated ( 1-2 seconds), then something writes in german, and then it starts again (two bars loading quickly...) and it doesn't stop. I left it for 20 minutes and it was still doing what I described, so I ejected the cd and proceded to the next step..
    3) I burned image of navigation 2013 maps with alcohol 120 at 2,4x speed, on verbatim dual layer dvd.. when I put the DVD in navi unit, nothing happens, but I can hear DVD spinning inside for 2-3 minutes and then it stops. the whole time something is wroted on display, like " keine ....dvd..." or something like that..
    Have I done something wrong?
    Thx for your help!
  7. #16
    bircaboy is offline Corporal
    28
    You have problems with step 3. What burner did you use?
  8. The Following User Says Thank You to bircaboy For This Useful Post:
  9. #17
    jomafi's Avatar
    Jul 2011
    Rottweil, Germany
    532
    30
    As bircaboy says i believe your problem is the Navigation DVD. Use IMGBurn or Nero Burning ROM as software. And the Plextor burners are the best for MFD2. Alternatively use LG-Burner e.g LG-4167B or LG-H22N. With this burners an the Verbatim DVD+R DL teh map-dvds all works in my unit. Probably the DVD-R DL should also work.
    B.R. Jomafi
  10. The Following User Says Thank You to jomafi For This Useful Post:
  11. #18
    Nov 2011
    I tried with two burners:
    1) LG BH10LS38
    2) Pioneer 116D
    I will try again with IMGBurn, and will let you know if it worked.
    *edit: should one of these burners work? I can buy them at my local store.
    1) plextor px-800a
    2) plextor px-40tsi
    3) plextor px-w5224ta
    thx
  12. #19
    jomafi's Avatar
    Jul 2011
    Rottweil, Germany
    532
    30
    Pioneer 116D should work perfect. Probably its neccessary to update fimrware.
    Here you can find recommended writers for Navigation DVD's: Recommended DVD Writers for Navigation software
    B.R. Jomafi
  13. The Following User Says Thank You to jomafi For This Useful Post:
  14. #20
    28
    I have pioneer 115d with 1.18 firmware, which is superb for RNS-E, RNS-510, but not for MFD2.
    I bought LG Gh22ns40 just for two copies of MFD2 and it makes very good ones.
    It's an old model, but i found it on ebay (new one).
  15. The Following User Says Thank You to bircaboy For This Useful Post:
