Page 1 of 8 123 ... LastLast
Results 1 to 10 of 75
Thread: MFD2/RNS2-DVD Unlock- and Firmwarethread
    jomafi's Avatar
    jomafi is offline Second Lieutenant
    Jul 2011
    Rottweil, Germany
    317
    18
    MFD2/RNS2-DVD Unlock- and Firmwarethread European Devices
    Hi guys,
    i make a new thread bundled with all infos and programs round about the MFD2-DVD, RN-S2 DVD before 45/06 and RN-S2 DVD after 45/06.
    At first, MFD2-DVD and RN-S2 DVD before 45/06 works with Canbus 1.6. The RN-S2 DVD after 45/06 works with Canbus 2.0.
    Please note, the following Software works only on the european versions of the named devices!!!
    Download-Links:
    MFD2 DVD (CB1.6): Share-Online - dl/9OJUJ0FMJF0 (Firmware 030)
    Golf/Golf+/Jetta/Touran/Caddy/EOS/Passat/Passat Variant
    RN S2 DVD (CB1.6):
    Share-Online - dl/D91R3FEMQ12 (Firmware 030)
    Touareg before 45/06, T5-Multivan
    RN S2 DVD (CB2.0): Share-Online - dl/QFJASHFMJZE1 (Firmware 019)
    Touareg GP after 45/06
    MFD2 DVD (CB1.6): Share-Online - dl/73BLR9FMJLB (Firmware028)
    Unlock DVD (all Firmwares): Share-Online - dl/X8TLS9FMQI2Z
    Please note, the following Software works only on the nar versions of the named devices!!!
    RN S2 DVD NAR: v47-NAR
    RN S2 DVD NAR: v49-NAR
    MFD2 DVD NAR: v50-NAR
    Please note, the last Firmware for RNS2-DVD from NAR was the v49!! The v50 doesn't work on RNS2-DVD, it's only for MFD2 DVD NAR
    Hope this thread can help you!
    Best regards
    oxili likes this.
    B.R. Jomafi
  2. The Following 9 Users Say Thank You to jomafi For This Useful Post:
    Nov 2012
    Re: MFD2/RNS2-DVD Unlock- and Firmwarethread European Devices
    I have touareg 2004 and navigation rns2 but I do not know which software I use,...I want to use WV DVD europa v10 2013 maps ,... thanks
    ibrahin77 is offline Lance Corporal
    Dec 2012
    Thanks jomafi
    mastrovetrio is offline Private
    Hello But what do you mean Touareg before 45/06 Touareg GP after 45/06. Where I see it on my nav.
    jomafi's Avatar
    Jul 2011
    Rottweil, Germany
    317
    18
    Go into System-Menu and look what firmware is installed. Obviously you should know when you touareg is produced
    B.R. Jomafi
    Excuse my English I'm using google. I have a 2006 Touareg TDI V3.0 with RNS2 I run the Firmware procedure 030, unlocked and mastered the maps on both DVD-R DL and DVD + R DL Verbatim with Pioneer 216D but I do not recognize the maps. I also clean the lens, now I try to install the firmware 019.
    What do you recommend? thanks
    jomafi's Avatar
    Jul 2011
    Rottweil, Germany
    317
    18
    After updating Firmware to 030 and use the old map, propably original map, have you the displaying the Navi-Signs in MFA?
    You must know, RNS2 with FW 030 has Canbus v1.6
    RNS2 with FW 019 has Canbus v2.0
    If the map is not accepted in most cases the unlock procedure must be repeated, or the map was not correct burned, probably with an incompatible burner
    B.R. Jomafi
    kittie1985 is offline Corporal
    21
    30
    Quote Originally Posted by mastrovetrio View Post
    use different writer (LG).
  10. #9
    What Canbus? where is it?
  11. #10
    jomafi's Avatar
    Jul 2011
    Rottweil, Germany
    317
    18
    Do you know anything about the electronic and communication platform of your car?
    Please google about canbus in vw...
    B.R. Jomafi
