Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Modified firmware for not power battery drain ?
  1. #11
    Re: Modified firmware for power battery drain problem ?
    no I don't have this last button. Its strange.
    I must cod with vag for show this option ?
    No camera on vehicule
  2. #12
    Jul 2011
    Rottweil, Germany
    473
    Normally not. It is strange. If you have acces to VAGCom or VCDS check in LCode in the byte 08 the bit 05. It is named: Speed Limit Info in Map.
    B.R. Jomafi
  3. #13
    Hi , ok I will check on VCDS in the navigation for see.
    Regards
  4. #14
    Speed Limit
    deleted...
  5. #15
    Re: Speed Limit
    Hi, all its good. You must enter on navigation on VCDS and uncheck SPEED tchr...
    Regards
