Results 1 to 10 of 15
Thread: Modified firmware for not power battery drain ?
    d3signz is offline Private
    Sep 2011
    Modified firmware for power battery drain problem ?
    Hi everyone.
    I search the latest firmware for all rns 510 Version who don't cause a power battery drain problem.
    Regards
    jomafi's Avatar
    jomafi is offline Second Lieutenant
    Jul 2011
    Rottweil, Germany
    321
    18
    Re: Modified firmware for power battery drain problem ?
    You can make your own firmware without power drain problem. In this case the VUCI must downgraded to compatible version from SW1200. All credits for this solution go to Josi, the real firmware-guru
    Fix for old CAN gateways:
    Gateway code (VUCI) from 1200 software - recommended for all A/B/C revision units to solve power drain problem with old* CAN gateways or as an workaround for dim screen problem after updating to firmware 2660 or above. It will update only VUCI part of RNS-510 and it is compatible with units running any software version past 1200. Includes MFSW/Maxidot fix for for pre-FL Skoda Octavia A5. Known issues:
    - no clock on display in standby mode
    - RVC not working
    at first flash your normal firmware. After this flashing, flash the fix-swl to downgrade VUCI. Thats all!
    B.R. Jomafi
    Sep 2011
    Quote Originally Posted by jomafi View Post
    You can make your own firmware without power drain problem. In this case the VUCI must downgradet to compatible version. All credits for this solution go to Josi the real firmware-guru
    - RVC not working
    Ok nice.
    So with this fix, I can install all rns 510 Version C, D, F, H on vw car before 2006 right ?
    This fix work with all SW version ? example : 3970 ?
    Regards
    Sep 2011
    Ok nice.
    Regards
    jomafi's Avatar
    Jul 2011
    Rottweil, Germany
    321
    18
    Yes, this fix works with all versions, because it is a separate SWL. One thing you must know. If RNS-510 complains about downgrade error, insert media and reboot unit by pressing Setup + Eject + Info/Mic/whatever top right button together. On US units, use Guide button instead of Setup button.
    B.R. Jomafi
    Sep 2011
    ok thanks perfect.
    So if I have a car before 2006 I insert this fix on rns 510 and hop good
    Sep 2011
    I have a last question.
    I updated my rns 510 H version and now I can't have "Display speed limit" on Setup->Map
    Regards
    jomafi's Avatar
    Jul 2011
    Rottweil, Germany
    321
    18
    Updated with which firmware version?
    B.R. Jomafi
    Sep 2011
    4120 the latest.
    But I think option missing before software upgrade..
    Its very strange.
    Now I can't have speed limit..
    jomafi's Avatar
    Jul 2011
    Rottweil, Germany
    321
    18
    Go into setup, then to map and last button must be about speed limit. Have you checked this?
    If you have front camera in your car it must be coded with diagnistic system in Lcode of RNS510...
    B.R. Jomafi
