Results 1 to 10 of 12
Thread: Phaeton 2005 year Navigation
    overman's Avatar
    overman is offline Private
    I need CD with maps for WV Phaeton 2005
    What navi system stay this? VDO?
    Slons is offline Command Sergeant Major
    248
    30
    Re: Phaeton 2005 year Navigation
    Yes. VDO Dayton.
    http://gpsunderground.com/forum/show...post#post16255
    It is a system that is made by VDO Siemens and is comparable to MS5000
    overman's Avatar
    thanks
    I try
    overman's Avatar
    where find update CD for MS5000 (WV Phaeton)
    It is not a MS5000 but a derivate
    You will have to ask VW but I doubt if there ever was an update since the system went out of production in 2003
    matis35 is offline Lance Corporal
    I have 2004 Phaeton. But the VDO dyton Cd does not start working.
    I have burned Disc for many cars and they works, but this is not working. Whats wrong? Any tricks?
    I burned with pioneer, IMGburn software, speed 4x, used verbatim cd, second mode and finished the disc. Something else need to do?
    A 2004 Phaeton with factory fit navigation uses the "nprmal" Navteq Non C-IQ cd's
    Has it occurred to you that the unit might be defective?
    Quote Originally Posted by gazo View Post
    But the old original CD is working fine!
    In that case you did make an error
    I have burned many cd's for Phaeton navigation but never encountered any problem
    Are you confident that the copy is really in Mode 2?
    PS
    A set of CD's from Navteq costs Euro 169, the same set from Volkswagen for Phaeton costs Euro 599
