Results 1 to 10 of 17
Thread: Help with a Phaeton year 2008...
    man20cese's Avatar
    man20cese is offline Staff Sergeant
    92
    What type of navi installed in this car? This is a picture of the model of this car: 2008.
    What type of DVD map I have to swrach for? Is a MFD2 system? If yes, can I unlock it with unlock cd for use backup?
    Re: Help with a Phaeton year 2008...
    You could find all the information you need on the various VW Forums
    The system is called RNS810 and is almost identical to the RNS510
    It uses the same DVD-s
    rv65 is offline Lance Corporal
    That unit is the Infotainment system.
    marius_nij is offline Command Sergeant Major
    214
    19
    Quote Originally Posted by gazo View Post
    Wrong. RNS810 is on Phaeton 2009-2010 and looks like this:
    http://www.oneighturbo.com/wp-conten...een-111108.jpg
    I stand corrected!
    The Infotainment system is made by Aisin and is a direct family member if not twin of the Audi MMI system
    It uses the exactly same DVD's as the RNS-E with 2 DVD's covering Europe (€ 399 each)
    don2702 is offline Corporal
    28
    try with vdo cds, it worked for me. I put cd which im using in bmw x5 2002 and it worked
    214
    19
    Quote Originally Posted by don2702 View Post
    are you sure your phaeton is 2008 with dvd navigation?
    i know that phaeton 2002-2007 with cd navigation use the vdo cds.
    The Infotainmaint system was only fitted in 2008 models and works with DVD's
    Hi, my father has the same car and hence satnav system and it uses CD'S not DVD'S. VDO Dayton will work just fine
    24
    gazo this is VDO Dayton system!!! CD working in phaeton manufactured this year!!!
