Thread: RNS510 with Garmin Maps
    cbx7t0p is offline Private
    Since it is possible to alter a BMW map for use on a VW RNS510, it is possible to do the same with an IMG file from Garmin Map Source ?
    Re: RNS510 with Garmin Maps
    Please do not misinterpret the possibility you have noticed.
    BMW Professional and RNS510 are both units from Siemens VDO and are basically identical with regard to navigation software.
    That is why the databases are interchangeable to a certain extend.
    No other software will run on these units.
    And you should praise the lord since Garmin is really rubbish software based on US conditions and in fact unsuitable for European conditions.
    For example:
    If you plan a route and you select Avoid motorways, the system will do so but also avoid national roads and departmental roads
    Then you will end up with a extremely funny routeing advice!
    I was told that the maps for the RNS510 is from Tele Atlas
    rv65 is offline Lance Corporal
    RNS-510 uses Navteq maps.
