Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Mfd cd
    mmolvid is offline Paid Member
    Mfd cd
    Hi!
    Anyone have the latest european version thats been out for MFD (1) i.e. the CD version?
    nass24's Avatar
    nass24 is offline Private
    15
    Ativon is offline Corporal
    The Netherlands
    22
    Re: Mfd cd
    I read and saw that the newest cd's (2010-2011) are allredy out!
    Did anyone found them online somewhere so we could dl them?
    Thanks for your replay.
    monsi is offline Corporal
    29
    Re: MFD2 CD Version
    Does anyone have maps for that type of navigation? -MFD2 CD I have tried
    http://gpsunderground.com/forum/showthread.php?272-Blaupunkt-Travelpilot-DX-2009-2010-10CD-s
    and it does not work. The CD also wont read any bourned audio CD's, only originals. Have anyone the solution?
    Re: MFD CD Version
    Please note that if you want to ask something, you should not do this in an item that has no relation with your question
    • You have downloaded the correct cd's
    • Most MFD2 units from VW do not like copied CD's whether Navigation or Audio
    • There are only a few writers that can handle the writing of the DX cd's correctly and produce a legible copy
    • Some have tried more than 50 times without any succes
    29
    Re: MFD CD Version
    Thank you for the answer! My writer works well on all(VW,AUDI;BMW,...) navigations. But there was also a problem with audio CD's. It wont read it.. maybe is the laser (pickup) bad in radio...
    Re: MFD CD Version
    If the unit has a bad laser it may still read audio cd's but not necessarily navigation discs
    The method used for reading navi discs is completely different from reading audio cd's
    die
    die is offline Master Sergeant
    136
    Re: MFD CD Version
    I see... This makes me think I found an answer. I have tried to use Germany TravelPilot DX CD in a MCD Navigation system (says it is compatible) but the unit did not read it, it displayed the message: "Please Install the compatible CD with MCD system" (or something like that).
    Is this because the CD copy was at a poor quality and I should change the writer?
    Thanks a lot!
    die
    136
    Re: MFD CD Version
    Quote Originally Posted by die View Post
    Thanks a lot!
    BTW, the car with the MCD system is from 2003 if this matters....
    Re: MFD CD Version
    I use Verbatim cd's and I write on the lowest speed possible. For me that is 1x with clonecd. You can give it a try
